Radio stopped working. All other items in car are working. Where is the fuse for the radio? Location of box and label if possible
Mar 5, 2008 at 9:12 AM
BMRFIXIT
CERTIFIED EXPERT
Power box under hood near the battery check fuse # 13 its 20A
check fuse block on left side of dash # 3 its 15A and #4 its 20A
Mar 7, 2008 at 6:39 PM
THOMRHINE
MEMBER
[quote:36468d9f88="BMRFIXIT"]Power box under hood near the battery check fuse # 13 its 20A
check fuse block on left side of dash # 3 its 15A and #4 its 20A[/quote:36468d9f88]
thanks for info..chwecked every fue in the ca inside hood and on drivers side, The fuses you suggested were all ok Any other suggestions?
Mar 29, 2008 at 9:21 PM
BMRFIXIT
CERTIFIED EXPERT
pull the radio out and check for power and ground and if all OK then radio no good
