2002 Dodge Neon No power
2002 DODGE NEON
101,000 MILES • 4 CYL • FWD • MANUAL
INDECK2222
My 2002 dodge neon does not have the get up and go like it used to. i have replaced the spark plugs and wires. also i installed a cold air intake to get better air flow and it does run like i think it should. What could the problem be. i have heard that they have problems with head gaskets but i have no oil leaks.
May 26, 2010 at 6:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
lot of things can cause a lack of power to engine. PCM and ground wiring to PCM could be bad, fuel pressure may be restricted, engine coolant temperature sensor, throttle position sensor, MAP sensor etc.... Is the engine light on? For the head gasket, just because oil is not leaking doesn't mean anything, in fact usually the oil would increase due to coolant mixing into it.
May 26, 2010 at 7:08 PM
