The 2002 Neon has a front (right side) motor mount connecting the timing case cover to the passenger front wheel well frame. It has a transmission mount connecting the transmission to the driver's front wheel well frame. There are also 2 aluminum stabilizer bars on the passenger side (upper & lower) to keep the engine from rotating.
The car vibrates badly most of the time. Both stabilizer bars have been replaced. The transmission mount has been checked and appears OK.
Question: Is the right side mount a solid mount or rubber mounted? This is the only thing I can see that might be causing the vibration, but I can't seem to find an answer or a part to replace it. An experienced answer would surely be appreciated.
Thanks
Fred
Thanks
Fred
Dec 27, 2007 at 7:11 PM
