2002 Dodge Neon Fluid is fine. What could be the problem?
2002 DODGE NEON
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
KMAUL001
My power steering stopped working a couple of days ago. I checked the fluid and it is fine. The belt on the pump seemed a little lose but it was hard to tell. There is no screeching or an other noises when I try to steer my car. What could the problem be? Is there a way to check my power steering pump inexpensivly?
Mar 24, 2010 at 3:13 PM
BMRFIXIT
  • 19,053 POSTS
Check if the power steering pump putting out pressure
raise the RPM and check if that improve the steering
also suspect rack and pinion
Mar 25, 2010 at 6:08 AM
