2002 Dodge Neon engine
2002 DODGE NEON
107,000 MILES • 4 CYL • FWD • AUTOMATIC
EAGLETALOND
well a few days ago the transmission was starting to slip, and the check engine light came on, so i was thinking of bringing it to the shop next week,
well today i was coming back home from a cofee shop and i noticed a hum from my cd player. upon pulling into my driveway my car pops out of gear, so i figured whatever i shut my car off. i went to go move it about 5 minutes later and the car started i put it in reverse and it died. with my cd changer lights flashing , i tried it again and the engine wouldnt even crank.
any ideas??
Jan 23, 2009 at 9:29 PM
JDL
  • 16,098 POSTS
Hello, do you have any kind of theft system on the vehicle?
Make sure the battery has a full charge and the cables/wires are clean and tight on both ends.
Nothing is froze-up, can you turn the crank by hand?
There is a starter relay in the power distribution center, you can do some testing there. Make sure the tranny is in park or neutral and the e-brake is set, block the drive wheels.
Jan 24, 2009 at 12:42 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect alternator
charge ,jump battery and start the engine
check running volts and charging system
EAGLETALOND
thanks guys, actually there is no car theft system, this used to be a dealer car ( dealer owner owned it) so it is pretty much fully loaded (IE, cd changer sun roof keyless entry)
i tried the code reading process and nothing was working, at one point my fuel gauge didnt even work.
Jan 24, 2009 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
check the battery
and terminals
Jan 24, 2009 at 6:41 PM
EAGLETALOND
alright guys thanks for all the help, but the problem has been fixed, it was all one big fustercluck.
heres what happened and what was fixed
radiator broke inside, causing the tranny fluid, and radiatior fluids to mix.
this caused my tranny to mess up inside with a loss of fluid causing the faulty shifting issues
electrical errors were due to grounds. being touched with fluids, and
so new radiator, and flushing of all fluids, cost me a total of 350
was that a good price..
Feb 8, 2009 at 5:35 PM
BMRFIXIT
  • 19,053 POSTS
Not a bad price
good luck and happy driving
Feb 9, 2009 at 6:20 AM
SCOTT0024
  • 28 POSTS
hey I just had the exact same problem, replaced the radiator it ran great for about 5 days then the trans started to slip. I did do a trans filter a fluid change, any help would be great
Mar 23, 2009 at 11:13 PM
BMRFIXIT
  • 19,053 POSTS
was the coolant mixing with the tranny fluid ?
check for codes
was the correct tranny fluid used (ATF +)
Mar 24, 2009 at 5:42 AM
SCOTT0024
  • 28 POSTS
actually the trans. fluid mixed with the coolant.
installed new radiator flushed motor, trans and filter change. it ran great for a few days the it started to slip and now it wont come out of 2ND gear, still has reverse. scan for codes revealed p0700 and p0755.
Mar 24, 2009 at 7:08 PM
BMRFIXIT
  • 19,053 POSTS
Had one Saturday in the shop with the same codes replacing solenoid pack solved the problem good luck and let me know
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_274.jpg
Mar 24, 2009 at 8:03 PM
SCOTT0024
  • 28 POSTS
do you know if this is a part i have to get at the dealer, or will most auto parts stores have them?
Mar 24, 2009 at 8:17 PM
BMRFIXIT
  • 19,053 POSTS
We were unable to get it through the part store
my local tranny shop had it in stock for ½ the dealer price
Mar 24, 2009 at 9:18 PM
SCOTT0024
  • 28 POSTS
Cool, thank you for you help it is appreciated.
Scott
San Jacinto, ca.
Mar 24, 2009 at 11:09 PM
SCOTT0024
  • 28 POSTS
I found the trans solenoid pack, but if i install this do i have to program it or is this already done.
Mar 26, 2009 at 6:55 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect battery
Clean area before removing the old solenoid out
remove speed sensor out
remove center wiring bolt connector
remove 3 holding bolts
remove solenoid and gasket
clean gasket area
install new gasket and solenoid
reconnect battery
starter and check tranny fluid
drive safe
Mar 26, 2009 at 7:51 PM
SCOTT0024
  • 28 POSTS
Thank you for the info.
I will let you know how it turns out..
Scott
San jacinto,ca.
Mar 26, 2009 at 9:22 PM
