2002 Dodge Neon Code P0340
2002 DODGE NEON
BREEZE2810
Computer problem
2002 Dodge Neon Automatic
Car died while was being drove and will not start back up. Checked codes got code P0340-Camshaft Position Sensor Circuit Malfunction - Replaced the Camshaft Position Sensor and the Crankshaft Position Sensor. Car still will not start, what else could be causing this? Reset computer and same code come back.
Feb 1, 2009 at 6:53 PM
JDL
  • 16,098 POSTS
Did you check the wiring circuits to the sensors. ref voltage--ground-- signal. The cam and crank sensors use the same ref voltage and ground. I believe the cts also uses the same ground.
Feb 2, 2009 at 9:42 AM
BREEZE2810
Ended up being timing belt. Mech said it was giving code because crankshaft was not turning because of timing belt. Thanks for responding though.
Feb 3, 2009 at 9:17 PM
JDL
  • 16,098 POSTS
Glad you got it fixed.
Feb 4, 2009 at 8:59 AM
