2001 Dodge Neon Tranny Drain Plug? Where?
2001 DODGE NEON
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
QUICKSAND
Tranny drain plug, Is there one? Trying locate it but I don't see it.. Where exactly is this drain plug?
Do i have to drop the entire pan to drain it? And is there a oil fiter in there?
Thanks.
Apr 27, 2009 at 2:29 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:488b672171="QuickSand"]Transmission problem
2001 Dodge Neon 4 cyl Two Wheel Drive Automatic 150000 miles
Thanks.[/quote:488b672171]
There is no tranny drain plug, you will need to drop the pan in order to change the fluid. Yes there is a tranny filter in the pan attached to the valve body.
Feb 24, 2021 at 6:12 PM
QUICKSAND
Thanks! It has to come down, noticed a gasket leak. Anyone here try tapping a plug on that pan?
OBXAUTOMEDIC
  • 3,711 POSTS
It is a pain and can be very messy. Suggest getting one of these to use with you oil drain pan will help keep fluid off drive
https://www.2carpros.com/forum/automotive_pictures/188069_transdrainpan_2.jpg
I have had a couple people try only to have to purchase a new pan. Because of it leakng. They don't put one in most vehicles cause there just isn't room to do it. .
