2001 Dodge Neon - Oil Problems
2001 DODGE NEON
GREGIND
  • 4 POSTS
I have a 2001 Dodge Neon and noticed that sometimes when I'd start it that it would blow white smoke out of the tale pipe then after it that would not show any more signs of smoking when driven. I looked at the engine and upon insepecting the engine I noticed that their is oil on the spark plugs and wires on cylnders 3 and 4. I had would like to know if the problem is a seal somewhere and how I would go about fixing it. Is it possible for me to fix? The car runs ok, is it safe to drive if I can't fix it and need to get it repaired? If I have someone do the job how much do expect it to cost? By the way I have a somewhat above average knowledge of cars: I have replaced brakes(front and rear), radiators, done tune-ups, and even replaced the valve cover gaskets on my brothers 1994 Dodge minivan.
Thanks in advance for helping me!!
Aug 21, 2006 at 11:56 AM
JAGTECH06
  • 7 POSTS
The oil on your spark plugs are from a leak around the O-Ring seals that seal the gap between your spark plug galleies and the valve cover which in turn leads to oil seaping onto the spark plugs and burning and creating the smoke. Once you buy a valve cover gasket it should come with 4 O-rings that will fix that problem right up. No need to take it anywhere. Just takes about 30 minutes.
Oct 17, 2006 at 11:58 PM
