this car started overheating when i covered up a crack it had on the radiator, so i took the thermostat of, but it still would overheat, the catalytic converter heats up real bad, not sure if that's normal. i can tell when its overheating because when i try to give it gas its a little rough and i have to push a little harder on it. i think that the coolant isn't been circulating correctly, it might clogged up, took it to a mechanic he said everything looks normal,yes the fans turn on.please help
May 31, 2008 at 8:05 PM
