2000 Dodge Neon power outlet ........ fog lights
2000 DODGE NEON
142,000 MILES • 4 CYL • 2WD • AUTOMATIC
AKON
checked all my fuses my power outlet/lighter just wont work.
my fog lights there is no button whatsoever to turn them on or off they just randomly flick on when i hit my high beams or turning signal ...
HELP ?
Sep 22, 2010 at 1:47 PM
As far as the lighter, check to see if there is power from the fuse to the wire that runs to the lighter. If there is, then check the wire for continunity. Chances are there is a break in it.
For the flg lights, they have a switch. If I recall, it is on the high beam switch. The very end of the handle should pull out to turn them on.
Let me know what you find.
Oct 4, 2010 at 7:08 AM
