2000 Dodge Neon Only High Beams work
2000 DODGE NEON
ANGELWINGS200688
Electrical problem
2000 Dodge Neon 4 cyl Two Wheel Drive Automatic
We have a 2000 Dodge Neon where only the high beams works. We've checked the lights to ensure they are both high/low beam bulbs, have replaced the headlight switch located in the steering columun and ensured the fuses are functioning properly. We have checked all electrical contacts to make sure there is sufficient electricity to the important areas of the engine. However, when the lights are turned on, only the high beams work
Oct 16, 2010 at 12:34 PM
JDL
  • 16,098 POSTS
In the diagram, the violet wires under the fuses, are voltage for low bean, right and left. Use a voltage tester on the fuse circuits, headlamps on dim. The violet wire with white tracer carries voltage from dimmer switch to fuses.
https://www.2carpros.com/forum/automotive_pictures/170934_neon_headlamps_1.jpg
Oct 16, 2010 at 12:48 PM
ANGELWINGS200688
There is no power to those 2 fuses (17 & 18), how do we solve this issue?
Oct 16, 2010 at 2:01 PM
JDL
  • 16,098 POSTS
That voltage comes from the dimmer switch, I'd have to check circuit to and from switch.
Oct 16, 2010 at 2:13 PM
ANGELWINGS200688
So this would cause the high beams to remain on at all times? Even when the running lights are the only thing turned on? There are no other lights, except the high beams, that are ever on
Oct 16, 2010 at 2:34 PM
JDL
  • 16,098 POSTS
The low beam does use those fuses, the highbeam doesn't. In the diagram violet wire with white tracer is for low beam. Red wire with orange tracer is for high beam.
Dec 19, 2010 at 4:45 PM
