2000 Dodge Neon Brake Light comes on but no visible brake i
2000 DODGE NEON
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
STINEY
My brake light came on and I checked the fluid and it was empty. I filled the resevoir and pumped the brakes, I check the brake pads and rotors and they are fine. The brake light went out after I put fluid in but now the reservoir is empty again and I can not detect a leak under the car and I don't know what to check to fix the problem. Can you help?
Sep 28, 2009 at 2:00 PM
BMRFIXIT
  • 19,053 POSTS
Pull rear brakes and check wheel cylinder
also check master cylinder for leaks
Sep 30, 2009 at 8:08 PM
