Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Neon
Interior
Instrument Cluster
Lights
1999 Dodge Neon instrument lights not working
1999 DODGE NEON
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
LITTLEEBUDGUY
MEMBER
FOLLOW
The speedometer and those lights wont work but the other lights do. I replaced the fuse and still no luck.
Jun 10, 2010 at 12:04 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
does the dome light work when you turn switch on manually? if not then switch may be bad. if it does then remove gauge cluster and inspect bulbs.
Jun 10, 2010 at 1:12 PM
LITTLEEBUDGUY
MEMBER
The dome light works but the gauges doesnt. turn signals are ok too. It keeps blowing the fuse every time i turn on the headlights
Jun 10, 2010 at 6:01 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
which fuse? if instrument panel fuse blows everytime the headlamps are turned on then the headlamp switch is bad
Jun 10, 2010 at 8:10 PM
