The steering rack on this vehicle suddenly started leaking, draining all fluid in minutes. Refilling anf looking ander the vehicle it appears to be coming from the pressure switch. The lines are not leaking and the pump is fine. Is this common the pressure switch would fail and then leak all fluid. Would replacing the sensor solve it?
Aug 17, 2008 at 1:54 PM
