I removed the throttle and the shifter bracket to clean off the rust and corrosion and when i lefted the throttle bracket off the shirter lever came up some out of the transmission and I need to know how to put back in place and reset it so the shifter and throttle work properly.Would you have a step by step and pictorial showing the inside of the trans so when i drop the trans pan and if needed the valve body Ill know exactly how and what to do or a link showing all this ? Thank You AL
Sep 11, 2009 at 7:26 PM
