1998 Dodge Neon shifter
1998 DODGE NEON
130,000 MILES • 4 CYL • FWD • AUTOMATIC
WALLACE FO
shifter won't go into park or low gear,can be put in reverse,neutral and drive and can be driven.
Apr 5, 2009 at 6:13 PM
CARADIODOC
  • 34,306 POSTS
Look for the shifter cable's casing moving on the transmission or under the dash. A loose mounting bolt will let the casing slide instead of making the cable push and pull the shift lever.
caradiodoc
Apr 7, 2009 at 9:57 AM
