1998 Dodge Neon 4 cyl Front Wheel Drive
car runs really rough at idle, even stalls a lot when its hot out. smoothes out when driving. had codes read and got cylinder 4 misfire {just replaced plus and wires, checked that number 4 is firing} downstream o2 sensor, cam position sensor, egr flow. is it likely one problem causing other codes. if so where should i start
Jun 13, 2010 at 11:30 AM
