my car broke a timing belt, i replaced all bearings gaskets and had all new valves installed after the rebuild it gets fuel but no voltage to coil pack if i unplug the connector and check the voltage two of the wires has 6.7 volts with ignition on but when i plug it back in to the coil the asd and the fuel pump relay clicks twice and i lose the voltage to the coil connector what could cause this??
Dec 19, 2008 at 8:58 AM
