i have a rough idle and even worse when the engine has a load on it(in gear) here are the fault codes:P0201,P0202,P0300,P0302. i have changed plugs,wires,air filter,ASD relay,cleaned the TB.i can disconnect the injector connectors on #1 and #2 and have very little change in the way the engine runs.i tested the injectors and they all read around 12 to 13 ohm.and can i use a jumper wire from injector # 3 to # 2 and #4 to #1 just to see if it is the connectors?or not?
Jan 4, 2008 at 11:02 PM
