1998 Dodge Neon Engines compression test
1998 DODGE NEON
IRONMAN44320
Engine Mechanical problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic
i was performing an engine compression test after replacing the timing belt and idler pulley. Does the valve cover need to be on during this test to ensure compression
Oct 2, 2008 at 5:04 PM
Hi:
No, the valve cover has nothing to do with the cngine's compression. However, if you crank the engine without it on, you will end up with a mess. Oil will be pumped to the top end.
If you have any other questions, let me know.
Oct 3, 2008 at 10:36 AM
