Engine Performance problem
1998 Dodge Neon 4 cyl Front Wheel Drive Manual 275 00 miles
have a few codes that come up and i was wondering if you could tell me what i would need to replace or repair.i have a 1998 dodge neon 2 door manuel w/2.0 SOHC i have replaced plugs and wires aitfilter, cleaned out the TB and checked for vac. leaks.my car jerks and bucks when i have the car in gear(any gear) when i put it in neutral it runs lot smoother.i tested the injectors and all read around 12.5ohm .and when i unplug the connectors to #1 and #2 injectors there is not much change in the way the car is running.if i do it to #3 and 4 it makes a BIG differance.the codes are 27-injector driver control circuit open or shorted. 43-ignition coil driver open or shorted misfires 42-no voltage detected at ASD relay out put. And the codes came up like this 12,43,43,27,27,42,55
Mar 6, 2009 at 11:22 AM
