1998 Dodge Neon dodge neon code
1998 DODGE NEON
FRANKY_119
Engine Performance problem
1998 Dodge Neon 4 cyl Front Wheel Drive Manual 275 00 miles
have a few codes that come up and i was wondering if you could tell me what i would need to replace or repair.i have a 1998 dodge neon 2 door manuel w/2.0 SOHC i have replaced plugs and wires aitfilter, cleaned out the TB and checked for vac. leaks.my car jerks and bucks when i have the car in gear(any gear) when i put it in neutral it runs lot smoother.i tested the injectors and all read around 12.5ohm .and when i unplug the connectors to #1 and #2 injectors there is not much change in the way the car is running.if i do it to #3 and 4 it makes a BIG differance.the codes are 27-injector driver control circuit open or shorted. 43-ignition coil driver open or shorted misfires 42-no voltage detected at ASD relay out put. And the codes came up like this 12,43,43,27,27,42,55
Mar 6, 2009 at 11:22 AM
BMRFIXIT
  • 19,053 POSTS
This is what need to be done reset the codes start and drive the car until check engine light come back on
when it does get the codes
and let me know what you have for codes
Mar 7, 2009 at 8:46 PM
