Welcome to the forum. Are you saying the starter won't even crank? I'd have to make sure the battery has a full charge, around 12.6 volts is the generic spec. Also check battery connections, engine running, check the charging system. If you have a digital multimeter, we can can give you some testing info. If no crank, have you tried cranking in neutral?
Another possibility, is a battery drain. Next, I'd check the circuits at the starter relay, underhood fuse box, pdc, power distribution center, whatever you want to call it.
Jan 18, 2010 at 10:45 AM
