1998 Dodge Neon A/C not working
1998 DODGE NEON
150,000 MILES • 4 CYL • FWD • MANUAL
PILOTFLYER
The compressor will not engage when A/C is selected. A/C clutch relay seems to operate fine. Does that mean either the clutch or compressor are bad? How do I troubleshoot?
Jul 23, 2009 at 10:22 AM
BMRFIXIT
  • 19,053 POSTS
Start by checking system pressure 1st
check for codes 2nd
Jul 23, 2009 at 10:20 PM
PILOTFLYER
I checked the pressure, and it was nil on the low side. Added some oil and freon, and now the clutch cycles on and off in a few second intervals. Is the most likely cause the Pressure switch? I am getting a gauge set today to check both high and low.
Aug 8, 2009 at 1:06 PM
BMRFIXIT
  • 19,053 POSTS
Most likely system low and need more 134A
Aug 8, 2009 at 7:57 PM
