Did the spark plug test no blue spark. Checked codes got a code 12 and code 54 going to replace camshaft position sensor tommorrow. Any suggestion if that doesnt work. Also changed coil pack
[quote:beb92b814a="rasmataz"]engine turns but wont start whats the problem? Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing[/quote:beb92b814a]
Sep 12, 2010 at 2:43 PM
