1997 Dodge Neon fuel pump fuse blows
1997 DODGE NEON
BIRDHUNTER61
Engine Mechanical problem
1997 Dodge Neon 4 cyl Two Wheel Drive Automatic
have problems fuel pump fuse blows on start up have trace for ground ,removed the 2 main connections and trace it down to the black/light blue wire going to ecm side of plug have even cut that wire from 4 in from ecm plug in it has no ground from engine side but is grounded on ecm side. check the green/orange wire it is good I understand that this black/light blue wire feeds from ecm to sensors, have shake the wires at ecm plug in's the car started up without blowing the fuse but the alt light stay on and it run great for about 2 hours , started up 3 or 4 times great then next morning got in car and fuse blows again help me please do u think it is in the ecm ? I have trace all the other wires that feed off the auto/shut down relay and fuel pump NO broken or grounded wires found.
Sep 19, 2008 at 10:04 PM
Sounds like a problem with the PCM auto shut down relay control circuit
Sep 19, 2008 at 11:08 PM
