the woman broke down had alternator replaced and she was driving and it quit.. will crank but doesnt have spark??
Jul 14, 2009 at 2:39 PM
JDL
CERTIFIED EXPERT
Hello, are there any codes? You should be able to get some codes by cycling the ignition switch. Usually if there is no primary voltage at the coil pack and injectors, with the engine cranking, I look for an rpm signal. You shouldn't replace anything without checking wiring circuits.
