1996 Dodge Neon Tensioner Pulley and Timing Belt failure
1996 DODGE NEON
140,000 MILES • 4 CYL • FWD • MANUAL
BDIZZLE82
The other day my car lost power as I was driving down the highway and going up a hill. I listened closely to hear what was going on, did not hear anything but shortly after the engine died and would not start. I further discovered that the timing belt housing was damaged due to the belt slipping off the pulley, however it never fell completely off and the tensioner pulley was ruined. I have since heard that there may be extensive internal damage due to it being an intereference engine. I was wondering the proper way to check for damage. I have removed the valve cover and there appears to be nothing wrong. Any help or suggestions would be greatly appreciated.
Aug 13, 2009 at 5:42 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The damage if any will be internal, replace the belt and any faulty pulleys, check the vale timing and do a compression test to check for bent valves.
Mark (mhpautos)
Aug 13, 2009 at 6:19 PM
