1996 Dodge Neon 101,399K can't get fireout of the coil
1996 DODGE NEON
LEANN_2001_99
It jumped time so we had the timing belt and had the head redone. It was running like a new one then after 30 minutes of running the car shut off, as if someone turned the key off and the car has not started again. We put a new crank sensor on it bought a new battery tried a new coil pak nothing has helped weve checked all the fuses. We get fire to the coil pak but not out of the coil pak. Can someone help me?
Feb 28, 2006 at 5:12 PM
2CARPRO JACK
  • 11,533 POSTS
Post in the correct forum or your post will be removed
Thanx
Mar 1, 2006 at 5:52 PM
