1995 Dodge Neon voltage fluxuating
1995 DODGE NEON
200,036 MILES • 4 CYL • FWD • AUTOMATIC
COREY D
  • 4 POSTS
car has a skip so i tested voltage and at the battery i am getting 10-19 volts when running. when i use the pos on the battery and ground at the frame i get 14.4 only once in a while i get 12.5 for a half sec. all of the grounds i cleaned and reattached that go to the battery on both ends. what would cause this?
Nov 10, 2008 at 5:24 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes
codes will help point u in the right direction
suspect alternator
Nov 10, 2008 at 5:55 PM
COREY D
  • 4 POSTS
i checked no codes or gauge light. i am in the 12volt industry (car audio) and i have never seen anything test like this before.
Nov 10, 2008 at 6:39 PM
BMRFIXIT
  • 19,053 POSTS
This is why I asked for codes
this system is self diagnose and always running self check
I would suspect a bad ground
run a temp wire between battery negative side and alternator mount bolt
and recheck
Nov 10, 2008 at 8:48 PM
COREY D
  • 4 POSTS
i just got this car couple weeks ago but i added 0 gauge - battery to frame and frame to motor. i havent added alt pos to battery pos because i didnt have a metric nut on hand.
Nov 10, 2008 at 9:13 PM
BMRFIXIT
  • 19,053 POSTS
Run battery to motor with out the frame
Nov 10, 2008 at 9:25 PM
COREY D
  • 4 POSTS
well i replaced the alt today and in this car was a real pita. it didnt fix the problem come to find out the voltage regulator is in the PCM. i am going to have to find a used one. is it 95,96,97 the only yrs that will work?
Nov 11, 2008 at 7:23 PM
