1995 Dodge Neon running rough
1995 DODGE NEON
AARONDC
1995 Dodge Neon 4 cyl Automatic 150,00 miles
My 95 dodge neon is running rough. It cuts out and idols rough. When you are driving down the road it will run ok for a minute then start cutting out and jerking. There is no code. I have changed the upper sensor, plugs, wires, and fuel filter.
Thanks for any help.
Mar 16, 2009 at 10:19 AM
RACEFAN966
  • 5,029 POSTS
Ok what upper sensor have you replaced? Can you include a pic if your not sure what it is called. I would like to know if you done any testing and if so what? Do you have a digital multi meter? Get back to me and we will go from there.
Mar 16, 2009 at 1:02 PM
AARONDC
I have replaced the upper oxygen sensor. I have tried checking it by turning the key off and on to read the codes..the check engine light is not on. I also have plugged in my meter and checked for codes. It is not showing any errors.
Mar 16, 2009 at 3:14 PM
RACEFAN966
  • 5,029 POSTS
Ok if the light isn't on then you will not get any codes. So with that do you have a digital multi meter? I would like to test the TPS and the coolant temp sensor. Get back to me and we will go from there.
Mar 17, 2009 at 10:52 AM
