1995 Dodge Neon help
1995 DODGE NEON
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
SJJONES9
The dashboard guages aren't working at all what do I check, what do I do?
May 12, 2010 at 10:15 AM
INTERNETMECHANIC
  • 700 POSTS
Check fuse 11--5amp, left side of dash, fuse block. Not only check the fuse, use a voltage tester on the fuse circuit. The circuit goes hot when you turn on the key.
May 12, 2010 at 1:02 PM
