1995 Dodge Neon Engine running rough
1995 DODGE NEON
86,000 MILES • 4 CYL • FWD • AUTOMATIC
PHILLIPM1
Hi, My name is Phil and i reasently purshed a 1995 dodge neon with 86,000 on the motor the motor was put in the car about 3 months ago. The car runs good but just reasently i will be driving and the car will lose power and slow down and you got to stomp the gas pedal and it will pick back up. i ran a computer check and i came back with three codes ( igition coil) - ( EGR vaule)- And map sensor. i replaced the coil and map sensor and i tested the EGR and it was good. so i bought some new plugs and upon installison the old plugs were drinsed in oil like oil is pouring in on the plugs what could this be i am stumped over this?
Feb 21, 2009 at 9:42 PM
Check the engine compression both dry and wet tests to determine if its rings/valves/cylinder wear-
Feb 21, 2009 at 10:58 PM
