Engine Cooling problem
1995 Dodge Neon 4 cyl Front Wheel Drive Automatic 190. miles
symptoms:
* dash indicator shows engine hot.
* may be a leak beside timing belt.
not sure if it is overfill.
*replaced the thermastat twice.
* resevoir constantly needing refill.
*both fans work.
* no heat inside car,when you put on heater to offset heat.
* cannot smell any odor from floor of passenger side.
* no smoke or fluid coming from tail pipe exhaust.
* did not start once, though it does now.
* gurgle sounds from the pipes?or rad? when shut off car..hear after 10 secs or so of shutting off motor.
[img:f4c26de17f]http://www.2carpros.com/forum/automotive_pictures/214308_jessica_posing_wit_my_car_1.jpg[/img:f4c26de17f]
symptoms:
*both fans work.
Jul 16, 2008 at 12:22 PM
