1961 Dodge Meadowbrook wiring
1961 DODGE MEADOWBROOK
AILIMAC
Electrical problem
1961 Dodge Meadowbrook 6 cyl Two Wheel Drive Manual 0
I actually have a 1936 Dodge D2 sedan, 230ci 6cyl eng which I am in the process of rewiring. Its a positive ground car. My question is: when wiring accessories like the clock do I use the positive (red) wire for the ground or do I use the black to ground (from the clock). Anyother info on wiring a positive ground system would be helpful also.
Pete
Nov 26, 2009 at 9:22 AM
MERLIN2021
  • 17,250 POSTS
Sorry, my books only go back to 1960, but wire it the same as a negative ground car in reverse, hook positve wire to clock ground. Only problem might be the clock may run backwards! If that happens, reverse the wires!
Nov 26, 2009 at 9:30 AM
