2007 Dodge Magnum ABS, ESP, BAS, Traction control, check en
2007 DODGE MAGNUM
36,122 MILES • 6 CYL • 2WD • AUTOMATIC
MMCKINNON3
Yesterday I was driving down the interstate at approx 70 mph when I noticed the vehicle driving in a "jerky" manner like it was trying to downshift. Shortly after (less than 1 or 2 miles) my my dash lit up like the 4th of July. My "ESP BAS", "ABS", and "traction control" lights all illuminated. Once these lights came on the vehicle becan to operate normally except that I could feel the rear of the vehicle sway a bit more and it just didn't feel as stable. Several miles later the "check engine" light illuminated. I went to the closest autozone to have the fault read and it turned out being a P0730 code for "incorrect gear ratio detected". From what I've read online it seems to be that the issue is with the TCM possibly. Does anyone have any clue if this sounds correct and if so does anyone have a clue as to how much the repair is going to cost? Thank you for any help provided.
Aug 13, 2009 at 12:09 PM
DUANE BLAKE
My 2007 with about 92,000 miles did vertually the same thing except I was braking (heavy) on gravel. Engine light, ESP light and my cruise control went down.
I had it in and code said it was the cam sensor, changed it didn't work so they are going to try the timing belt. 4 hour labor. See what happens Thursday.
Duane
Jul 13, 2010 at 10:01 PM
MMCKINNON3
Well i took mine into the dealer and I actually had three failures. If I remember correctly the three parts that needed to be replaced were the rear, passeneger hub bearing assemby, the speed sensor on that same wheel, and the intake manifold. This fixed any problems I was having.
Jul 14, 2010 at 7:09 AM
