2006 Dodge Magnum shifting out of park
2006 DODGE MAGNUM
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDDIE49
My 2006 Dodge Magnum will not shift out of park using the shifter. After removing the gear shift cover, i am able to press a small pink button to manually take it out of park. It shifts fine to & from every other gear. I dont know if this is a mechanical or computer problem. My check engine lite was & is on before & since this problem occurred
Apr 5, 2010 at 3:46 PM
TM34815
Was the button a button or more of a lever? did it cause the car to shift or just release the lock? does this button exist on a 2005? where was it located? in side gear shift in on right hand(passanger) side of shifter?
Jul 21, 2010 at 1:25 AM
