Firing order, coil terminal locations. Code 301 misfire #1
1930 DODGE INTREPID
JCELEGANTE
  • 19 POSTS
dodge intrepid, 1996, 137,000 miles, 3.5L engine,
I have replaced spark plugs, and wires. Replace TPS from a different problem. Confusion from different sources of coil terminal locations. It appears that the 3.3L engine diagram is the closes fit.
Sep 10, 2007 at 6:51 PM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_firidr_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_mitchel_11.jpg
Sep 10, 2007 at 7:16 PM
[quote:7132952d6c="jcelegante"]dodge intrepid, 1996, 137,000 miles, 3.5L engine,
I have replaced spark plugs, and wires. Replace TPS from a different problem. Confusion from different sources of coil terminal locations. It appears that the 3.3L engine diagram is the closes fit.[/quote:7132952d6c]
Re: Firing order, coil terminal locations. Code 301 misfire #1 PO301 no.1 cyl. misfiring is it still popping? could be caused by the following:
Plugs and Wires are they OEM oarts
Weak coil pack for that cylinder, loss of compression-burn exhaust valve- vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), dirty fuel injectors, low fuel pressure, or even bad fuel
Sep 10, 2007 at 7:25 PM
Have been looking for that for the last 10mins. couldn't find it, am I dumb or am missing something
Sep 10, 2007 at 7:28 PM
SERVICE WRITER
  • 9,123 POSTS
Clearly not a dumb a$$...wise maybe :wink:
Engine Performance/Specifications....Fig 1
Sep 10, 2007 at 7:38 PM
JCELEGANTE
  • 19 POSTS
Thank You I'll make sure that this is how I have them. This is much clearer than the Haynes manual. The confusion I had was looking at it flat on the paper and then flipping it 90' :arrow: as it is on the side of my engine.
I'll insert a picture tommorow it will help show what I'm talking about.
To clarify,
Is this for the 3.5 iter and not the 3.3 liter engine?
Or are they both the same?
Also thanks for the additional Ideas.
This might be the real issue :D
:shock: I didn't even know I had a response. I find it difficult to check. I actually found this by selecting "view my posts."
There was nothing listed in my in box or a reply sent to my e-mail.
I guess I'm still learning How to use your site. :o
Thanks again.
Sep 12, 2007 at 6:50 PM
SERVICE WRITER
  • 9,123 POSTS
I believe they are the same based on the info I have. Don't feel bad about learning the site, so are we :roll:
Sep 12, 2007 at 7:02 PM
JCELEGANTE
  • 19 POSTS
These are 4 pictures of the coil terminal From passenger side:
https://www.2carpros.com/forum/automotive_pictures/96838_Distributor_004_2.jpg
https://www.2carpros.com/forum/automotive_pictures/96838_Distributor_005_2.jpg
From front of vehicle.
https://www.2carpros.com/forum/automotive_pictures/96838_Distributor_003_3.jpg
https://www.2carpros.com/forum/automotive_pictures/96838_Distributor_002_1.jpg
See how the coil terminals are down on the side of the engine. It is somewhat dificult to read diagrams that are one dimentional. My car was running very rough last night. I almost didn't make it home from work. I switched these I put the even numbers on top and the odds on the bottom. :?: This seems to work the best! :D This car is so messed up! :? :idea: I noticed ealier the question about OEM parts. Well, yes and no. Yes I have Champion spark plugs specefied in my manual. But my wires aren't OEM. :oops: I thought they were good. I bought them at Auto Zone. :oops: Not the cheapest and not the most expensive set they had.
Sep 13, 2007 at 10:59 PM
JCELEGANTE
  • 19 POSTS
I have tried to give votes and points to both of you.
It doesn't seem to work.
It says error why give zero points.
I only have .6 points. I try to give more and it says I don't have enough points.
If I try to give a decimal amount, it says it only accepts integers.
I don't know how this whole thing works.
I don't know when to send a Private Message or Just post it.
I do appreciate all the help given me.
John
Sep 14, 2007 at 1:59 AM
SERVICE WRITER
  • 9,123 POSTS
John, Don't worry about the points and all that BS, focus on the car. Our system has some serious defects in it. You appreciate it and that's fine for me. Back to the car:
https://www.2carpros.com/forum/automotive_pictures/30961_coil_2.jpg
IF my info is right and my interpretation is right, this is how it should work. The top three are 3-1-5 cylinders. On the engine, the number 5 cylinder is on the passenger side closest to the firewall, then comes #3 and the front one is the #1 cylinder. Keep in mind what Jesses said:"Weak coil pack for that cylinder, loss of compression-burn exhaust valve- vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), dirty fuel injectors, low fuel pressure, or even bad fuel" IF the routing is right, and code is still there and the wires are on tight and the plug is gapped right, then we need to change directions. And if this proves true, pull the plug on the misfiring cylinder, take a pc and up load it. When you put it back in, move it to another cylinder and put that cylinders plug in the number one cylinder. IF the mis-fires moves to the other cylinder, we have a bad plug. IF the mis fire stays on number one, well pick up there.
Sep 14, 2007 at 5:43 AM
JCELEGANTE
  • 19 POSTS
THANK YOU!!! :!:
For the exact picture. This is what needs to be in the manual.
But...It :D
Now is running very rough. I don't dare Drive it like this. I changed the wires to exactly what you had shown. I then started the car. It was shaking and... I don't know quite how to describe it.
Shouuld I make a direct swap between the bottom and the top. I'm at work. I need to drive this car home tonight. :shock:
Sep 17, 2007 at 10:29 PM
JCELEGANTE
  • 19 POSTS
I swapped the top for the bottom directly it still was rough. So I swapped 6 & 2. It seemed to run better. Something is still not right.
Sep 18, 2007 at 3:17 AM
SERVICE WRITER
  • 9,123 POSTS
You can either clear thecodes, run the engine and pull the codes from the computer to find out where the mis-fire is. OR pull on plug wire at a time with the engine running and see if there is a perceptible difference, if none then you have a cylinder that is misfiring.
If so, put a sparktester on that wire and see if there is no spark. If you have spark, pressure test the cylinder.
You going to cause more damage by running it as unburned fuel may be getting into the crankcase...smell the oil and check the level. If fuel is present get the oil otta there. I'll see what I can dig up to help.
Sep 18, 2007 at 4:48 AM
JCELEGANTE
  • 19 POSTS
On my way home the car was running rough. I stopped and switched the odds back to the top and all in the same order that the diagram showed. It then ran so rough that I could hardly start it. If I put in drive it would die. I swapped 3 with 5 and 6 with 2. It ran very well. But on the highway around about 70 mph it really stated cutting out. I again am not sure where to go with this. I should at least change my fuel filter. I am thinking that I should find a car like mine and see how its sparkplug wires are set. Well I thought I should add that info. before I go to bed.
Sep 18, 2007 at 4:52 AM
TOM HARRIS
where is the firing order for a 2011 dodge charger v6
Dec 21, 2016 at 3:54 PM
Please start a new question
Best, Ken
Dec 24, 2016 at 2:04 PM
BENCHPRESSMAN9
Engine Mechanical problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 134500 miles
can you give me the firing order for the 2.7 litre
thanx
Dec 24, 2016 at 2:05 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_70.jpg
