I have a 98 intrepid that had an engine swap done a couple of years ago (2.7 to 3.2). I've been using the same computer that was on the 2.7.
It has been running fine until lately. It started as the engine stumbling like a throttle position sensor might do. Then the stumbling turned into dieing.
This will happen after about five minutes (coincident with temp rising?). It will run fine until then the just die and will not restart.
I plugged in the autotap tool and there aren't any codes happening perm or temp. So no diagnostics from OBDII to help.
I'm not sure where to start from here.
May 4, 2006 at 1:09 PM
