I own a 95 Dodge Intrepid V6 3.5 24 valve with 120,000 miles on it, All of a sudden the compressor died on me, i've already tried to refill with R134 but as soon as the hose is hooked up and i start filling the line i hear a hizzing noise coming from the front of the engine. The first time i tried it the compressor kicked in but went out again about 10 seconds later. I then tried to use a leak stopper and a dye to try to detect if there was a leak but i wasnt able to find anything, now, I checked the fuse relay in the engine compartment and the relay itself seems to be working just fine, however if I bypass the relay and just connect 2 of the terminals with each other by using just a regular cable the compressor kicks in.
Any advise will be greatly appreciated. I live in the state of Illinois and temps up here are reaching triple digits.
Thanks.
Thanks.
Aug 3, 2007 at 11:57 PM
