2004 Dodge Intrepid po441 codes
2004 DODGE INTREPID
LILDAY50
  • 7 POSTS
Computer problem
2004 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
i have a po441 code on my car. how much does it cost to get it fixed. i have to past inspection.
Dec 20, 2008 at 3:07 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me the model of your vehicle. Is it just a ES, SE or SXT. Also the engine size in liter and the 8th digit of your VIN.
Dec 20, 2008 at 4:09 PM
LILDAY50
  • 7 POSTS
2004 dodge intrepid se 6 cylinder the last eight digits of vin # are 4h639078 4dr. sedan
Dec 20, 2008 at 6:53 PM
IMPALASS
  • 3,112 POSTS
Hello – lilday50,
Thanks for the info…….you must have miss understood me……I need the 8th digit of your VIN, not the last 8. If you are not sure then please provide all of your VIN.
Your vehicle shows 3 different 6 cylinders……2.7L VIN R, 3.5L VIN G, and 3.5L VIN M.
Dec 20, 2008 at 10:40 PM
LILDAY50
  • 7 POSTS
i am so sorry. i did misunderstand. the numbers are 2b3hd46r94h639078.
Dec 21, 2008 at 8:05 AM
IMPALASS
  • 3,112 POSTS
Hello - lilday50 Okay........there we go.......... Well, based off of the code it is the proportional purge solenoid. Now you are supposed to do some checks of the system with a scanner to make sure that is the problem. I just kind of followed the troubleshooting tree to see where it would take me. I have attached a few things for you. The item location, a couple of pics of that. What it is and what it does. The actual troubleshooting chart information The removal and installation if you or someone can do that. An estimate of a shop doing it. The shop estimate is again, an estimate. Could be a little more or less but that is ball park. Also remember, without test equipment I am only giving you a best guess.....but this should get you in the area. Hope that helps. Description and Operation Notes DESCRIPTION All vehicles use a proportional purge solenoid. The solenoid regulates the rate of vapor flow from the EVAP canister to the throttle body. The PCM operates the solenoid. OPERATION During the cold start warm-up period and the hot start time delay, the PCM does not energize the solenoid. When de-energized, no vapors are purged.
https://www.2carpros.com/forum/automotive_pictures/248015_101729289_1.jpg
The proportional purge solenoid operates at a frequency of 200 hz and is controlled by an engine controller circuit that senses the current being applied to the proportional purge solenoid and then adjusts that current to achieve the desired purge flow. The proportional purge solenoid controls the purge rate of fuel vapors from the vapor canister and fuel tank to the engine intake manifold.
https://www.2carpros.com/forum/automotive_pictures/248015_4_35.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_5_24.jpg
SYMPTOM P0441-EVAP PURGE SYSTEM PERFORMANCE WHEN MONITORED Cold start test. Engine Running. Small leak test passed.. SET CONDITION The PCM activates the EVAP Purge solenoid gradually increases to maximum flow. During flow, the PCM looks for the NVLD switch to close. If the PCM does not see the NVLD switch close at maximom flow an errow is detected. Two Trip Fault. POSSIBLE CAUSES Good Trip Equal to Zero NVLD Switch Operation Vehicle History and Service Bulletin Investigation Checking EVAP Purge Solenoid Functionality EVAP Purge Vacuum Supply Verify NVLD Operation REMOVAL
https://www.2carpros.com/forum/automotive_pictures/248015_3_58.jpg
The solenoid attaches to a bracket near the air cleaner. The solenoid will not operate unless it is installed correctly. Disconnect electrical connector from solenoid. Disconnect vacuum tubes from solenoid. Remove solenoid from bracket. INSTALLATION The solenoid attaches to a bracket near the air cleaner. The solenoid will not operate unless it is installed correctly. The top of the solenoid has TOP printed on it. The solenoid will not operate unless it is installed correctly. Install solenoid on bracket. Connect vacuum tube to solenoid. Connect electrical connector to solenoid.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_38.jpg
Dec 21, 2008 at 9:07 AM
IMPALASS
  • 3,112 POSTS
Hello – lilday50
Oh, one other thing……….Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
C25
07/01/2003
Campaign - A/C Drive Belt Tensioner Bracket
Dec 21, 2008 at 9:08 AM
