2004 Dodge Intrepid Electrical Problems
2004 DODGE INTREPID
CRCAMC1973
Electrical problem
2004 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 100k miles
Ok.... So my intrepid sat for about a year because the ac didn't work and it was to expensive to fix. Now its out of mothballs because its the best I have. I thought it was having alternator problems. I have a volt meter that plugs ino the cig lighter. It would randomly read low volts and then eventually die. It also randomly kick back on and be fine. I replaced the alternator with a used one. It was a little better for a while but then started up again. When its low volting enough it gets stuck in second gear and the radio shuts off. After that it starts getting hot. It runs hot for a while (probably too long), and then poof.... alternator is back and working and I'm back at full voltage. I'm beginning to think its a computer thing. I'm hooking it up to a battery charger at night to get back and forth to work.
Aug 26, 2010 at 9:57 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.There is trouble code's for your charging system.Can you drive over to a auto part's store like auto zone and see if you have any code's that would be a big help if you had a code.It could tell us where to start looking.Let me know what you find.
Aug 26, 2010 at 11:54 AM
