2003 Dodge Intrepid rear brake caliper
2003 DODGE INTREPID
80,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID S
will i need a brake caliper reset tool for rear caliper or can a C- clamp work like on the front brakes. thank you very much
Feb 5, 2008 at 6:31 PM
BMRFIXIT
  • 19,053 POSTS
[quote:74d51d04af="david s"]Brakes problem
2003 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 80000 miles
will i need a brake caliper reset tool for rear caliper or can a C- clamp work like on the front brakes. thank you very much[/quote:74d51d04af]
I believe your e brake work independently from the calipers and you have a set of rear e brake shoes that sits in the rotor drum area
and if so you need NO special tools and you can use the C clamp.
Good luck
Feb 6, 2008 at 7:58 PM
