2002 Dodge Intrepid Turning Signal Stops blinking (both lef
2002 DODGE INTREPID
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIAMI_VETERAN
When I engage the turn signal, both left or right, it works fine for about 5 to 10 seconds and then lights just stop blinking. Stopped or moving, same issue occurs. Please help if this sounds familiar. [email protected]. Thank you for your time.
Sep 24, 2009 at 8:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check out the flasher relay. There is a panel located between the end of the dash board and the drivers door. Open the door, take off the cover, and the flasher is on the top left of the fuse panel.
how about the hazards , do they work properly?
Sep 24, 2009 at 9:58 PM
MIAMI_VETERAN
The hazard lights are working perfect. I sat there and waited for about a good minute or two. I'll be attempting to locate the flasher relay later on today. I work on computers, so I can relate to finding the exact part and replacing it. Now it's just identifying the issue. I will let you know how it goes. I plan on replacing the flasher relay and hope it works. But I will let you know. Thanks for the great direction!!
Sep 25, 2009 at 3:27 PM
