I need to get timing done on my car, mechanic says not to do it, better of to put new engine in it, because type of engine it is. intrepid 2001
Jan 20, 2008 at 10:03 AM
BMRFIXIT
CERTIFIED EXPERT
[quote:a564079875="sammiey6"]Engine problem
2001 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 149000 miles
I need to get timing done on my car, mechanic says not to do it, better of to put new engine in it, because type of engine it is. intrepid 2001[/quote:a564079875]
what is the engine size?????
what king of problem are you having ?
why is the tech saying engine no good
let me know
Jan 20, 2008 at 10:22 AM
SAMMIEY6
MEMBER
2.7 6cy, tech says it could have bent valves or piston
its a chain and a belt
no start do you have spark and fuel
did the chain brake how’s the compression
if compression is OK and you have spark check if you have cam signal
disconnect the cam sensor and try to starter it will crank for a bit
let me know
Jan 20, 2008 at 1:31 PM
SAMMIEY6
MEMBER
turns over won't start, no spark, tech says compression fine
Jan 21, 2008 at 6:52 PM
BMRFIXIT
CERTIFIED EXPERT
[quote:c1a670aeca="sammiey6"]turns over won't start, no spark, tech says compression fine[/quote:c1a670aeca]
ok no spark did he check the crank sensor
hook it up to scanner and read data as cranking look for crank and cam signal and if you have sync
Jan 21, 2008 at 7:27 PM
SAMMIEY6
MEMBER
done all that, says these engines are know to blow up like popcorn
Jan 21, 2008 at 8:35 PM
BMRFIXIT
CERTIFIED EXPERT
[quote:838d09737d="sammiey6"]done all that, says these engines are know to blow up like popcorn[/quote:838d09737d]
OK ?!?!
they are not the best engines made but
still doesn’t explain why no spark
if you have good compression
no noises just no start and no spark !!
that’s is a 1st for me changing an engine because has no spark
seek a different opinion
let some one else look at it
Jan 21, 2008 at 9:21 PM
MOPARTECH9423
CERTIFIED EXPERT
Let's start from the begining. What engine is in your Inrepid? From your mechanic's answer it sounds like you have a 2.7L V6. This engine get a unfair bad rap from a lot of technicians. A lot of people don't like this engine because they don't understand it or the sight of three timing chains scares them. Now here are some important questions...
...did the enging jump time?
...are you doing this for maintaince?
If it did jump time then you most likley will need an engine. One tooth off could bend several valves.
