2001 Dodge Intrepid oil light comes on along with knock
2001 DODGE INTREPID
104,000 MILES • 6 CYL • FWD • AUTOMATIC
J.STIEG
  • 361 POSTS
I have a car that the oil light comes on when the oil level is correct. The oil light starts blinking and then stayes on, it immediatly after the oil light comes on it starts knocking. do you know what causes this? Jared.
Dec 18, 2008 at 6:21 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Your loosing oil pressure and you hear bearing knock. Need to get looked at A.S.A.P. or you may lose engine.
Let me know and will advise
Dec 19, 2008 at 11:39 AM
J.STIEG
  • 361 POSTS
I figured it out on myself that the loss of oil pressure was due to a secondary timing chain tensioner that came lose. So I tightend it down and oil pressure is back. I runs fine now except for knocking for one second at startup. this only happens if set over night. After the engine is just shut off it start back up normal with no noise.
I suspect the primary chain tensioner o ring is bad causing the oil pocket to slowly drain back down.
Do you think that is it, if not then what? Jared
Jan 5, 2009 at 11:30 PM
DOCFIXIT
  • 18,828 POSTS
That is a possibility to check remove right valve cover look at tenisioner plunger can you see the machined grove? If so then indicates chain and associated parts worn. If not you can try and reset plunger.
Jan 6, 2009 at 8:34 AM
