2001 Dodge Intrepid Car acting up need help
2001 DODGE INTREPID
189 MILES • 4 CYL • FWD • AUTOMATIC
CHICAGO24
  • 7 POSTS
I have a 2001 Dodge Intrepid, 2.7 liter, automatic transmission and 189,000 kilometers. Today when I was backing out of the driveway it went into reverse fine. When I went in drive all the lights on the dash, REVERSE, DRIVE, PARK, were all on. And when I drove my odometer wouldn't work and it wouldn't go into the next gear.I take that back it pops in to frist gear after i let off teh gas but after that it will not go in to the other gears. I know this car has a lot of senors and i trying to find out should i get the sensor replaced or the whole transmission
Mar 15, 2010 at 9:18 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Trans needs to be scanned for sensor inputs to see what may have failed. There are several so scanning is only way to tell. Then post results and will recomed repair.
Thanks for donate
Mar 15, 2010 at 11:02 AM
CHICAGO24
  • 7 POSTS
NOW I HAVE TAKEN THE CAR TO AUTO ZONE AND THEY HOOK IT UP TO A COMPUTER AND IT CAME UP WITH SENSOR THIS SENSOR THAT SOME IN THE TRANSMISSION AND SOME IN THE ENGINE. I JUST GOT THE ENGINE FIXED AND I HAVE RESET THE BATTARY. NOW WITH THE COMPUTER GIVING ME THESE CODES AND THERE LIKE 10 OF THEM NOW WOULD THAT MEAN I HAVE TO REPLACE THE TRANSMISSION AND I FOR GOT TO SAY SOMETIME WHEN I DID DRIVE IT IT WILL CUT OFF BY ITSELF AND IT WILL START BACK UP. I AM LOST ON WHERE TO START OR WHAT TO DO
Mar 15, 2010 at 1:20 PM
DOCFIXIT
  • 18,828 POSTS
If you will post the codes in P0xxx format will try and unravel the problem.
Mar 15, 2010 at 1:37 PM
CHICAGO24
  • 7 POSTS
codes
P0700 & P0715
now i have change the input and the output speed sensor and i am having the same problem. now what do i check for now.
Mar 17, 2010 at 5:31 PM
DOCFIXIT
  • 18,828 POSTS
Speed sensors not at fault P0700 means TCM reporting internal errors and must be replaced. Transmission Control Module location see figure
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_404.jpg
Mar 18, 2010 at 11:49 AM
