2000 Dodge Intrepid turning over but will not crank
2000 DODGE INTREPID
CHARLES HARRIS
  • 4 POSTS
Electrical problem
2000 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
2000 Dodge Intrepid 2.7 engine . will not crank but turning over
replaced the following, spark plug -crank sensor-fuel pump and not showing any fault codes
Feb 28, 2009 at 2:38 PM
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 28, 2009 at 3:04 PM
