2000 Dodge Intrepid Ticking on acceleration
2000 DODGE INTREPID
145,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBCHI
There is a slight knocking in engine when quickly accelerating as to pass or get into traffic speed. No sound at cruising speeds. Sound happens when accelerating from any speed. Almost like a lifter noise but quieter. Any thoughts on where to start? I think it is 2.7l
May 26, 2010 at 4:44 PM
CARADIODOC
  • 34,306 POSTS
Hi robchi. Welcome to the forum. The 2.7L is known for oil-related problems in the engine if the oil is not changed at the recommended intervals, but this sounds more typical of an exhaust leak. You might be able to replicate the sound by holding the brakes while trying to accelerate in gear. The leak will be in front of the catalytic converters, usually right where the exhaust manifolds bolt to the engine. It might not occur until the engine is warmed up.
If you are unsure, have a mechanic listen to the sound to give you a more definite diagnosis.
caradiodoc
May 26, 2010 at 5:59 PM
