2000 Dodge Intrepid location of neutral safety switch on do
2000 DODGE INTREPID
CORTJR
Electrical problem
2000 Dodge Intrepid 6 cyl Wheel Drive Type unknown Automatic 111000 miles
car wont start it wont even crank its like putting it in drive and turning the key.....(nothing)
could it be neutral safety switch and where is it located on 2000 dodge intrepid
Mar 13, 2008 at 5:31 PM
BMRFIXIT
  • 19,053 POSTS
Harley ever fail
check it in neutral
does it start ?
check fuses and relay
under hood fuse box
check /replace starter
u still need the N/S switch location
let me know
Mar 13, 2008 at 5:35 PM
Hold key to start position and look for power at the starter light green wire-not there check the starter relay at power distribution center then check then ignition switch. Also see below
https://www.2carpros.com/forum/automotive_pictures/12900_starter_circuit_5.jpg
Mar 13, 2008 at 5:41 PM
